Hi folks,
Battery warning light came on dash as driving home Wednesday night. Thursday morning it stayed off. Took it to a garage to check it over and they said the battery is fine, but obviously could be the alternator. Drove to work (25 miles) and it stayed off. As driving home last night...
originally my van (t6) wouldn’t hold charge overnight and when I came the next morning battery was flat. Checked and was getting 14.78V once engine was running. Checked to see what A it was pulling while completely locked and was dropping too less than 20mA. Took it for a battery check and they...
Hi everyone brand new to forum
Vehicle details 2016 t32 t-line 2ltr tdi 30,000 miles. Camper king conversion.stood for 3 days "battery flat" iv only had it couple weeks purchased van from Marquis lesure with a 3 year warranty. Rang them and they told me they would check it out. I put some miles...
Morning all,
Can't make this up... Any ideas how I can sort this... My life
The Lug has sheared the pos bolt, so I can't put it all back together...
The Lug is part of the main harness so I can't even just replace the Lug...
Got this Telematics error the other day. Cleared it first with Carista and then with VCDS, but it keeps coming back. On the dash.
Vehicle says everything is fine and there are no warning lights, but there's a periodic chime that's low and pings 3x.
Traveling in South America. Any specific...
My starter battery appears to have died over winter. I've a SWB Euro6 T6 model and I was wondering if anyone had any recommendations for a new battery?
Thanks!
James
When I installed my leisure battery I fitted a CTEK D250SE which works perfectly. But now I want to also install an electric hook up, I am okay with getting the mains power in to the van but am unsure how to set this up to keep my leisure battery topped up. My questions are these, is there a...
Hi everyone, Frank here from Norwich.
I bought a lovely second-hand T6 (2017 plate) and was wondering how I could use my Jackery power station to keep the starter battery topped up? Sadly, my van has to live outside since we don't have a garage or other undercover parking opportunity. Last...
Hi, I added some new DLR bulbs, but as it was not very good light conditions when testing the bulbs, the dip beam lights came on, but i noticed that the lights are flickering.. would this just be the alternator not generating enough current or something more sinister going on? cheers
Do i need to program anything to change battery in T6.1 2020?
The battery is 3 years old and lose the power pretty fast, almost down to 11,9V
So i need to change the battery to something better.
So flat battery this morning. Dash lights OK, and the remote unlock worked OK, but dim lights when the key was turned and the battery monitor was reading 11.15v. Its a 2018 van and the original battery was replaced under warranty within the 1st year (with another Moll that I suspect they got out...
Hi Guys, I've sold my van and just before I did this I decided to get the starter battery changed just for good measure.
The original battery was working fine before it was removed and it never drained much when sitting.
The spec of the new battery was slightly different and it was booked in...
Could someone or a couple of people next time they are at their van please pop the bonnet and check the part number on the battery control module on their negative battery terminal and let me know please?
Any T6 from 2016 onward. If you could let me know they year as well that would be great...
Hello.
I just replaced my battery. The previous one failed.
However, with the engine running OBDeleven showed battery voltage 14.4 volts - obviously the alternator charging.
I just coded in the battery, but one I do an OBDeleven scan it showed the battery as on being 12.2 volts, but then more...
Bit of an odd question, but how do the door mirrors behave on a T6.1 when the main battery is disconnected and reconnected?
I have to fold my mirrors in, via the door switch, in order to park it in my garage.
Soon I’m going to be disconnecting my starter battery while I do some work on it in the...
Anyone have any idea please
T6.1 Symptoms….
Passenger window fails to operate on either switch. If you leave drivers door window open and try to lock with remote the doors lock but the drivers window fails to shut. Also mirrors fail to spin up on lock. Also msg on startup on touchscreen...
Auxiliary battery I took out of my Ex RAC van, not been used for months but showing 12.47volts when I just checked. Free collection from West Yorkshire near Rochdale.
Good morning, on starting my 1966 BiTDI several yellow lights appeared: (1) tyre pressure (flashing then on constantly) (2) stability (3) ABS. The BlueMotion also became unavailable and remained so. Tyres all OK and have reset to no avail. Any help please? 1 sensor/fuse to rule them all...
Hi all, I am going abroad for 4 weeks and have to leave the van at work, I have got a smallish solar panel with controller to trickle charge the starter battery with crocodile clips. The van has a tracker and aftermarket immobilizer fitted so wanted to try and counter any current draw. My...
