steering wheel
  1. vincethomas
    For Sale T6.1 Steering Wheel Custom-Made Napa Leather
    Hi Guys, I have 2 T6.1 Steering wheels for sale. I had few hanging around and posted them all to be done and saved one for my T6.1 and other 2 are for sale. Selling them at the cost of rework (prices include VAT) 1st one was made from scratch, thicker with modified bottom, retrimmed in napa...
  2. M
    T6.1 Heated Steering Wheel
    Hi, for my 2023 t6.1 I'd like to upgrade the steering wheel to heated unit. I saw this one in local fb group and am considering placing an order. Being new to all this automotive stuff I would like to ask for some advice. First and foremost, are you able to tell if this will be ok for t6.1 ...
  3. Ads_Essex
    [T6] Show Us Your Upgraded Steering Wheel
    Following on from this thread, https://www.t6forum.com/threads/steering-wheel-upgrade.737/ I thought we could have a dedicated thread for showing off our upgraded steering wheels.. I bought a plastic flat-bottomed Passat MFSW off eBay for £60 and for £300 had it re-upholstered by CCSW. I...
  4. CJW
    For Sale Airbag
    From a 2016 T6. Of the two pin variety. Airbag loom is not the MFSW version, but can be swapped over if you’ve already got the loom. Only removed because I switched to a 3-pin Polo wheel when adding MFSW. £100 but open to offers. Collection preferred but maybe we can sort something out. I also...
  5. D
    T6.1 steering wheel with paddles
    i know this question has been asked regarding the T6, but is there a direct replacement wheel featuring the DSG paddles and retain the T6.1 airbag. From what I understand the airbag won’t fit on many other VW wheels. many thanks
  6. C
    Steering Play in odd place
    Hi all, Not sure if this is something that’s been covered previously. Noticed excessive steering play on my 2018 T6. Checked the usual places for play, track rod ends, all seem fine. Moved into the cab and looked at the steering column coupling area. I noticed play in an odd place. I have...
  7. dandan88
    Steering wheel help
    Guys I need a little help I’m replacing my steering wheel and I’ve released the airbag it… can I just release the connector straight away? I e taken the black connector off the battery Many thanks
  8. HoopDub
    Sold Flat-bottom Golf Mk7 TCR MFSW + airbag. £400
    Genuine vw golf Gti TCR flat bottom leather steering wheel. Lovely condition, very small mark on red leather 12 o'clock stripe. From a DSG, the paddles aren't original, easily removable if you want to fit it to a manual. Airbag included and buttons included. £400 Would take a T6 highline...
  9. Lee540
    Steering Wheel - Repair Kit
    Thought I'd share my efforts this weekend. Kit from Furniture Clinic, was about £21 with new customer discount code. Before: and After Not perfect but miles better!! Saved a fortune on a new wheels or recovered one. Might help someone out on here.
  10. Chrisab
    Steering play
    Hi all. Just need some advice. I bought a t6 California about 6 months ago and noticed the steering had some play in it when I move the steering wheel about 10-15 mm the front wheels don’t respond. I have checked the steering shaft in the cabin that all moved at the same rate as the steering...
  11. P
    MFSW - MultiFunction steering wheel
    sup guys, I have the multi function steering wheel with the shift paddles, but the right side of the steering ( right side function buttons and right shift paddle) is not lighting at all, while the left side works perfect, do you guys have any idea what could be the problem? is it the clock...
  12. RNelson
    T6.1 Show Us Your Upgraded Steering-Wheel
    Fallen out of love with the carbon.. thinking of changing and would love to know what you guys have upgraded to in your T6.1.
  13. racT6bus
    Judder through steering wheel
    Hi all, tried to find an answer to this, but can't find anything similar. My T6 (T32, 150PS, 6 Speed, SWB, Manual, Late 2016) has an occasional judder when between 1500 and 2200 revs across the range of gears. It seems to happen periodically at various stages through a drive, so when cold...
  14. K
    For Sale Highline steering wheel
    Wheel is in good condition and isn’t showing any wear. Came from a 2018 Highline. Was used for about 40k miles before it was swapped for a custom controls one. £50 Collected from Cheltenham or can post as I have the box. if you want me to ship these I’ll need to get a price and carrier...
  15. Lord Mfwic
    Sold Highline MFSW. £200
    For Sale. Genuine T6 Leather MFSW. Taken off my T6 Highline when it was on about 20K miles when I bought a flappy paddle wheel. The plastic bits are shiny as I have the Comfort Dash, not sure if others are the same. Absolutely prefect condition £200.00 collection only from Shrewsbury...
  16. andy greenwood
    Sold steering wheel + AIRBAG
    Non multi function steering wheel plus airbag . Airbag in excellent condition with no marks. Taken off our 66 plate camper. £125
  17. Jon
    Sold Highline T6 Standard Steering wheel.
    Perfect condition was used for about 30k miles before it was swapped for a flappy paddle one. Just the wheel you will need an airbag and switch gear just thought it would be good for someone who would like an undamaged replacement one. I was thinking £50 ? Collected from Northamptonshire but...
  18. B
    Worn Steering Wheel
    I just bought a VW TD 6, 2016 and the steering wheel is showing signs of wear, parts of it are glossy and parts of it Matt & dirty looking. Any recommendation on a kit to buy and restore it
  19. Pauly
    [Guide] T6.1 MFSW Steering Wheel Upgrade
    Upgraded the MFSW on my 2022 6.1 to a Golf MK8 haptic touch wheel and want to lay out how i did it, lots of these steps are not specific to this wheel so thought this would be a handy 'how to' guide These wheels are a straight swap but the electrical connections are a bit different so a few...
  20. Dav-Tec
    Sold T6.1 Custom Wheel
    Custom T6.1 wheel complete with Haptic buttons and Airbag £499 Inc shipping. Can be fitted at an additional cost. Advertised elsewhere for non forum members at £525 plus shipping.
