Whilst removing the interior panels both rear interior roof lights fell to pieces, this seem to have effected the front interior lights aswell, didn't think this was an issues until....
Its also seems to have effected the rear lights?
Now the break lights work, the hazards work, the indicators...
When I open the rear of my T6.1, the lights fade out after about 10 seconds. They didn't used to - they used to stay on for several minutes.
I've now knowingly adjusted anything. How do I increase the time-out?
Hi. I’ve done a search for this but can’t seem to find the answer- I’ve got a 2021 6.1 with factory led interior lights and would like to extend the time out. At the moment if I switch them on they go out after about 10 minutes and I would like to extend this to about 60 mins if possible. Could...
Hi all
Does anyone know if there is a female for this connector. Stupidly when I had my pop top added, I didn’t ask for the courtesy lights pop outs but just the cable. Having changed my mind the connection is in the wrong place at the rear and I can’t get it pulled to the pop out. I was...
My interior lights have stopped working now when I unlock the van with the keyfob or open one of the doors, they do still come on when i press the button on the overhead centre console. I would appreciate any advice on what may be the cause, only had this 72 plate vane van a month & seems to be...
Been a long time coming.
Need to make some space so I’ve gathered my van bits together to get rid of as I sadly don’t need them anymore.
Will end up in the tip in a few weeks if nobody claims them.
Collection preferred to save hassle posting, but can do @ buyers expense.
I regularly travel from...
Hi all, I have a T6.1 which I'm converting (slowly!) I had a Skylow roof fitted but couldn't decide what lighting I wanted in the back, so told them to leave the cables where I could access them.
I really want some adjustable mood type lighting in the back, I can't do the star-scape ceiling...
Hoping for some help with some entry lights for the driver/passenger steps as I cant find an answer.
I have the standard factory footwell lights which work off the courtesy circuit I assume as they go off when you put the ignition on. Can I tap of this and just run a feed directly to the step...
I am looking to re locate the OEM lights in the roof lining of the van.
Ideally an extension lead would be great but I imagine there are at the same shop as the unicorn poo.
So my next thought is, there must be a 'socket' that the 'plug' of the OEM loom fits into (ie like the back of the...
Brand new, boxed, genuine VW Passat B5 W8 LED interior ambient interior roof light
3B7947105F, 3B7947105F2EN, 3B7947105F 2EN, 3B7947105F 92Y, 3B7947105F92Y
An original and genuine new part VW Passat W8 interior overhead light in beige with ambient red LED lighting suitable for the following...
Hey all, hopefully this hasn't been discussed already?
I have a 2020 T6.1 T32 camper conversion which is great however there is no rear interior courtesy light. When I open the front or side sliding door the front interior light comes on but as its in the front it doesn't give enough light into...
I’m having an issue with the front interior light staying on.
The light illuminates when the door is unlocked, but stays on while driving.
After stopping it goes off after about 10 minutes.
Is this likely a grounding issue or switch in the door or handle?
Same on all doors btw, so...
Interior light stays permanently on when switched to door open, when the doors are all closed. engine off or on.
There is nothing on the dash to suggest the car thinks a door is still open.
Any ideas please?
Thanks,
Lee
Anyone know if I can add an extra light switch from the main panel? So the lights can be turned on/off from the back of the van?
What's the best way/procedure for this?
Cheers
Paul
Having changed the ceiling completely these are now surplus to requirement.
These can be collected from North Bristol, clevedon or happy to post at cost.
Hi I’m new to this so bear with me
I’ve fitted some foot well lighting and for some reason when I was putting all the dash back when I plugged the glove box light in it blew the fuse to the interior lighting , not so bad but I have no ignition it it’s all dead the only things that work are the...
With the thoughts of exploring the idea of putting some additional LED lights in the load bay of my 70 plate T6.1 Kombi I stuck a multi meter into the detached plug of the original rear LED ceiling light. I successful read the voltage, and then tried to get the current. I've now done...
Simple mod. Just unclip existing lights, swap over and plug new ones in! Much better than LED bulbs in your existing lights.
Straight plug and play.
Upgrade your factory fit rear interior lights to VW LED lights.
Plug and play with existing connection.
Free postage.
£8 a light or £15 a set of...
