Can anyone enlighten me as to the following errors.
I expect the near side ABS sensor, as that is generally the one that gets all the much and crud on it but can someone tell me anything else on these codes please?
Hi All, hope someone can help and provide a bit of advice.
I've just had a RAC code check on a T6.1 i'm about to purchase. It came back with lots of error codes as follows :-
ABS
1141 (intermittent)
1209 (intermittent)
Auto Distance Regulation
1289 (intermittent)
2055 (intermittent)
2068...
How do I find out about the remedy's people have found for the 132 kw t6 vw kombi transporter that has just developed a p0191 fault code . Rail pressure sensor range performance . Have replaced the sensor but the problem still persists . Clear the fault and you can drive 160 km no problem ...
I was driving this morning, coming to a stop at traffic lights and saw smoke coming from engine bay area. Smoke dissipated once I was moving again but Van went in to limp mode with flashing coil light.
Limited acceleration and speed but got me home.
18874 - Leak in Air Intake System |...
Hi all I’ve got a t6 140bhp started with a bussing/Zissing noise at about 1250/1650
under load but not just revving her up
had a Quick Look under the bonnet
all good no problem all bolts seem tight
no split hoses. After a M/way run coil light
comes on, code P0299 comes up is that just replace...
Good afternoon all,
I am posting this issue to try and get some clarity on the next steps with my tailgate and central locking.
Concerning a 2018 T6 Panel van in the throws of a conversion, For the past 4-6 months, the central locking has not been working, and the tailgate electronic switch...
The ESP warning light came on so did a quick scan with Carista and the following codes came up.
00778 steering angle sensor no signal
25809 power steering control module no communication
2516 invalid data received from dynamic control module
00166
Steering angle sensor no signal
Also stop start...
I've FINALLY got into this forum - didn't realise hotmail addresses don't work.
I have a 2016 150 T6 DSG with 70k.
2 weeks ago the coil light came on and the van kicked into limp mode. Later that evening the emision control light came on
Initially I used a basic code reader and pulled the...
I Have this (cheap) OBD11
The engine light is on and the code is P20EE which I assume is NOX sensor fault.
I have had this at least once a year and it has reset after driving around for a few trips.
This happened on a long drive in France but disappeared again after a couple of days.
Then it...
Greetings.
I’ve recently had the orange coil light flash up on start and a stop start error.
On checking I had the following errors:
P064C00 - Glow Plug Control Module
P172400 - Signal for starter lock, short to ground
I cleared these a couple of times and would run fine and but now they are...
currently got this code that won't clear
from what I can google it appears It might be an issue with carbon build up in the intake manifold?
anyone experienced anything similar .
the van is a 2018 204
I'm new to the forum. I have a 2021 shuttle which is showing an engine light. Code is p24ae which is the particulate matter sensor circuit according to my cheap reader. Is this something well known. Trying to save myself a day of hassle with the dealer in this but there is a warranty...
Hey!
First post here, was mainly reading until now. Roughly two weeks back I finally got a T6 transporter (CXHA) with 150k on the clock. The van mostly stood still other than the drive back from the dealer (~120km), since I'm preparing it for the conversion. Yesterday on a short drive the...
Hi all, I’m hoping for a bit of advice regarding some issues I’m having with my van.
My battery light is on, my battery isn’t charging, and I’m struggling to figure out if it’s an alternator, battery control module or wiring issue.
I’ve scanned the van and I’m getting a 02252 code, although I...
Hi all
Sorry to ask but the following code keeps coming up on my code reader and want to know is it correct what it is saying.
P067200-Passive/Sporaaic Cylinder 2 Glow Plug Circuit
Is this a true code for no2 glow plug not working and just wants a new glow plug putting in ?
Just don’t want to...
Good evening, it might not be related but since having some work recently (gearbox out) I am getting this fault. It is very intermittent and sometimes doesn't occur for a while but other times it will being on the EML.
I have checked the pipework to the differential pressure sensor and that...
Evening all,
I've had the van for 5 months and mostly run it locally during weekends, whilst I decide on what day van conversion I want.
After using the van last night without issue I jumped in today and the Engine Management Light was on, no obvious problem or performance issue, I completed...
I've just set off to the lakes with the kids and the engine management light came on. Pulled over and run a quick scan with the below.
Do I need to worry or can it wait till I get home.
I'm only 2 hours from home and not planning on using the van while up here
2019 t6
Can I clear and see if...
