steering rack
  1. Rchrd
    How effective is the in-built Steering Column lock at stopping theft?
    I'm really appreciating all the helpful threads about security on this forum, lots of great advice, but one thing I can't find anything about (and I've searched), is how effective is the in-built steering column lock in the T6 at preventing thefts (if it's engaged!)? I know a disc lock has the...
  2. G
    Replacement steering rack
    Hi all The seals on the end of my steering rack have failed and now leak. I just wondered what experience people have had with non VW steering racks and if they last? Or if anyone has had there original rack refurbished? Thanks
  3. T
    T6.1 steering rack part numbers
    Hi all, i have a 2020 t6.1 and I have a tight spot in my steering more noticeable going round right hand corners. Power steering all works as it should. I thought maybe it was a CV joint or something like that. Had the van inspected and on a ramp, weight off the front end so wheels jacked...
  4. P
    For Sale T6.1 electric steering rack
    Will add pic and number ( one rack end missing ) Otherwise complete 200
  5. D
    Steering rack on the way out?
    Hi all, Need some advice…… I have a late 2018 DSG transporter 150 2wd. About 3 weeks ago I put the van into reverse and noticed it was vibrating through the cab and steering wheel. It has got worse progressively. I have extended warranty and AA/VW assist came out and told me the back engine...
  6. C
    Steering Play in odd place
    Hi all, Not sure if this is something that’s been covered previously. Noticed excessive steering play on my 2018 T6. Checked the usual places for play, track rod ends, all seem fine. Moved into the cab and looked at the steering column coupling area. I noticed play in an odd place. I have...
  7. F2JON
    Found T6 Steering rack
    A friend of mine is after a steering rack for his t6 , anyone know the best place to get one ?
  8. P
    T6 electric rack ( bcm canbus help)
    T6 electric rack. Any one know which canbus pins are used. From the bcm As there’s a few from bcm. I assume it’s not hvac as there differnert colour
  9. L
    2017 T6 Steering rack failure
    Friday just gone I had my T6 all packed up with 3 mates, their bikes and luggage heading on a road trip to the Alps. I got only an hour down the road and had to pull over as steering went heavy, sure enough loud groaning too which as I pulled over I knew could only be one thing… AA arrived an...
  10. D
    Steering rack part number problem
    Hi all, I've got a 2016 t6 t32 Steering has alot of play and have had it to a garage who replaced steering column parts which didn't fix the problem. After looking at it my self you can hear/feel a nock in the steering rack it's self. I've gotten the part number from my rack which is...
  11. C
    Steering rack - removal
    Has anyone replaced the steering rac on a T6 if so how’s it done ?
  12. racT6bus
    Judder through steering wheel
    Hi all, tried to find an answer to this, but can't find anything similar. My T6 (T32, 150PS, 6 Speed, SWB, Manual, Late 2016) has an occasional judder when between 1500 and 2200 revs across the range of gears. It seems to happen periodically at various stages through a drive, so when cold...
  13. S
    T6.1 "Power steering with mobility aid" (PR-1N5) ?
    The T6.1 bodybuilder guidelines mention: 5.1.2 Selection of steering rack for conversions for people with disabilities In addition to the standard power steering (PR no. 1N3), Volkswagen offers the Transporter with power steering with mobility aid (PR no. 1N5) as optional equipment. The power...
  14. Angela
    Advice / Help - Steering Rack Problem 2017 VWT6
    Heya guys, you all usually have great advice for me, I own a VW T6 2017. It only has 12,500 miles on as it’s a Holiday and picnic wagon. We had the conversion from new. I have not long been told I have a steering rack leak after taking it in for a service. We have just moved to devon and...
  15. J
    Power steering rack noisy and leaking
    Afternoon All. My power steering rack is leaking oil and I've a noise when steering at low speed. Anyone encountered this before and can offer a solution. Cheers
  16. S
    Hi Guys wondered if someone could offer some advice please I have a 2019 T6 Transporter brought new just before the first lockdown has been professionally modified to a day van spec with 20 inch low profile wheels etc been really pleased with it excellent cruising beast use it with driveaway...
  17. L
    Steering rack leaking fluid
    Hi all, just got back from my local garage having popped in to see if they could look at a strange whining noise coming from the engine bay, I am not at all technical with vehicles. I am told now that the steering rack is leaking fluid after only 28,000 miles! This seems very low mileage for a...
  18. Lukavell
    Tie Rod dramas
    I've been fitting the first Koni front shock and T32 springs today supplied by Sterve @CRS Performance, hard work but I'm nearly done and the next one won't take so long! Has anyone else had to replace the steering rack tie rod when working on shocks/springs? I ask because the torx or allan...
